vcMultiDriverTarget
An object with properties to define necessary information to plan and execute a multi-driver motion.
Module: vcRobotics2
Parent: vcMotionControllerTarget
| BlendingType | vcMotionBlendingType | RW | Gets or sets the desired blending type. Also see BlendingValue. |
| BlendingValue | Real | RW | Gets or sets the value that defines how early blending towards the next motion may start. Also see BlendingType. |
| ExternalDriverValues | list[tuple[Integer, Real]] | RW | Gets or sets the list of external driver values to reach at the end of the motion. The integer is the external driver's index in this controller. |
| InternalDriverValues | list[tuple[Integer, Real]] | RW | Gets or sets the list of internal driver values to reach at the end of the motion. Not used for vcPtpTargets. |
| VelocityPercent | Real | RW | Gets or sets the desired velocity percentage as decimal value [0, 1.0]. |
